Fusion gets stuck generating 2D tool path
Once I got through my set-up and fusion starts to create tool path it gets to about 54% progress and stops. I’ve tried it a couple times but need to abort after it just sits there at 54.5% for ever. I have not had trouble with other projects, just this one.
Thanks,
-Ryan
I had trouble with a file sticking at 90% forever and and it finally finished. Turns out the item woukd have been 124” tall x 73” long. I didnt check my dimensions before creating toolpath. Check that
I checked the size it’s only about 18" tall x 12" wide. It has a lot of cut lines. My computer meets the minimum spec for Fusion, but just. I also get a message about my graphics card isn’t optimal sometimes. Maybe time for computer upgrade?
I had the same issue with the United States logo that said Merica it ran all the way up to 93. 9% and stop did it two different times I gave up on it and decided to try it again a few days later and something I did made it go through not sure but the file was not oversized meaning it was close to being able to fit on my table cut although I have had issues with dxf files but went online and got a generator to change it into an SVG then everything worked out
I go through issues occasionally where it won’t generate and it locks up. Iirc, there’s a setting for how intricate it calculates the movements. It was in the tutorial videos and they said on more complex projects you may have to adjust that
