Does anybody know all the short cuts in fusion 360?
The hotkeys I use the most are
Esc release the tool from the cursor or closes a open menu.
X switch between construction and Standard sketch line
E extrude profile
O offset line
M move
S Search for tools … this is very useful
P project line and points
Ctrl Z undo
Ctrl Y redo
Ctrl C copy
Ctrl V paste
Ctrl/Print Screen to make screen shots for the forum
and here is a link to the rest
https://www.autodesk.com/shortcuts/fusion-360
Animate Workspace Commands
| U | Auto Explode All Levels |
| E | Manual Explode |
| P | Publish Video |
| M | Transform Components |
| C | View |
CAM Workspace Commands
| Ctrl + D | Command +D | Duplicate |
| Ctrl + G | Command + G | Generate Toolpath |
| Shift+S | Scripts and Add-Ins | |
| Ctrl + L | Command + L | Show Log |
Canvas Selection
| Ctrl + C | Command + C | Copy |
| Ctrl + X | Command + X | Cut |
| Hold Shift + Hold Middle Mouse Button | Orbit | |
| Hold Shift + Click then Hold Middle Mouse Button | Orbit around point | |
| Hold Middle Mouse Button | Pan | |
| Ctrl + V | Command + V | Paste |
| Ctrl + Y | Command + Y | Redo |
| Ctrl + Z | Command + Z | Undo |
| Roll Middle Mouse Button | Zoom |
Drawing Workspace Commands
| B | Balloon |
| C | Center Mark |
| Delete | Delete |
| D | Dimension |
| M | Move |
| P | Projected View |
| T | Text |
Edit Form Commands
Alt + Drag Add geometry
Alt + Control + Drag Alt + Command + Drag Add geometry and keep creases
Electronics workspace
/ Activate command line
H Add Hole
A Add Part
T Add Text
B Bus
C Change
Ctrl+C Command+C Copy
Delete Backspace Delete
D Dimension
Ctrl+D Command+D DRC
Ctrl+E Command+E ERC
E Errors
G Grid
Shift+L Label
R Manual Route
R Move
N Name
R Net
Alt+Ctrl+3 Option+Command+3 New Device
Alt+Ctrl+2 Option+Command+2 New Footprint
Alt+Ctrl+1 Option+Command+1 New Symbol
Alt+Ctrl+4 Option+Command+4 Package 3D Create
O Pad
Shift+O Pad Array
P Pin
Shift+P Pin Array
Ctrl+Y Command+Shift+Z Redo
U Ripup
Alt+Shift+P Option+Shift+P Ripup All Polygons
Ctrl+R Command+R Route Diff Pair
Shift+R Route Multi
Alt+Shift+S Option+Shift+S Run Script
Shift+U Run ULP
P SMD
Shift+P SMD Array
ESC Stop
Ctrl+Z Command+Z Undo
V Value
Alt+V Option+V Via
F6 Zoom to Fit
Ctrl+1 Command+1 Switch Sch Doc
Ctrl+2 Command+2 Switch PCB Doc
Ctrl+3 Command+3 PCB 3D View
S Shortcut Dialog
Generative Design workspace
| N | New Generative Study |
| E | Study Settings |
| C | Structural Constraints |
| L | Structural Loads |
Modeling Commands
R 2-point Rectangle
A Appearance
Shift + J As-built Joint
C Center Diameter Circle
Ctrl + B Command + B Compute All
E Extrude
F Fillet
2 Freeform Selection
H Hole
J Joint
L Line
I Measure
S Model Toolbox
M Move
X Normal / Construction
O Offset
3 Paint Selection
Q Press Pull
P Project
Shift + S Scripts and Add-ins
D Sketch Dimension
Shift + N Toggle Component Color Cycling
V Toggle Visibility
T Trim
1 Window Selection
Render Workspace Commands
A Appearance
Sculpt Workspace Selection
Shift + Up Arrow Grow selection
Alt + N Command + N Invert selection
Alt + O Control + O Loop grow selection
Alt + P Control + P Loop selection
Alt + Right Arrow Control + Command + Right Arrow Next U
Alt + Up Arrow Control + Command + Up Arrow Next V
Alt + Left Arrow Control + Command + Left Arrow Previous U
Alt + Down Arrow Control + Command + Down Arrow Previous V
Alt + M Command + M Range selection
Alt + K Control + K Ring grow selection
Alt + L Control + L Ring selection
Alt + J Control + J Ring shrink selection
Double-click an edge Select edge ring
Select two faces then double-click a third face Select face ring
Shift + Down Arrow Shrink selection
Ctrl + 1 Control + 1 Toggle box mode
Ctrl + 2 Control + 2 Toggle control frame mode
Ctrl + 3 Control + 3 Toggle smooth mode
Simulate Workspace Selection
| Ctrl + D | Command + D | DOF View |
| F | Force | |
| Ctrl + G | Command + G | Groups View |
| Ctrl + L | Command + L | Model View |
| N | New Simulation Study | |
| Ctrl + R | Command + R | Results View |
| E | Settings | |
| C | Structural Constraint | |
System
| Ctrl + Shift + S | Command + Shift + S | Recovery Save |
| Ctrl + S | Command + S | Save Version |
If you’re new to Fusion. I suggest you check out NYC CNC WEBSITE. For $100 you can sign up for online classes. They are the best school type clases I’ve found. He goes through every tool and scenario that you will come across. There is a second set of classes for CAM programming if you plan on a cnc mill in the future. Check it out… He goes through every one of the constraints and how to use them.
Product development online (PDO) on YouTube is also an excellent resource.
Sorry, 37 pages of keyboard ‘shortcuts’ doesn’t cut it… Geez, I’m still trying to remember CTRL-ALT-DEL!
Tin when do you find time to work, sleep and eat? ![]()
@TinWhisperer is not actually one person…
it is a group of Mennonite rebel computer hackers bent on providing state of the art support by downloading and having every manual for every piece of plasma related equipment in a database.
OR
A bunch of monkeys banging on keyboards actually proving the debate correct about what a bunch of monkeys can actually do banging on keyboards…
you decide…
