How on earth do u assemble this frame big holes small holes facing this way the the other holes dont have the big holes right?
The biggest recommendation I can make is to carefully study the images in the instruction manual which shows which tubes get used in which positions and associated fasteners used to attach them.
Ohhh yes y didnt I think of that? Thank u for all ur help
I second that. Look at the pictures to make sure that all of the holes in the picture are where yours are in real life - even the ones not being used for fasteners in that step. The big holes are typically on the outside surface so you can put the spacer tubes in the hole. But it’s the small holes that tend to be distinctive between the tubes/orientation. Place them, check the picture, lay out the hardware, check the picture, dry fit the hardware and then finger tight (except the ones they note need to be tightened).
I spent a couple of hours starting my build this afternoon. First laid out all of the parts then the hardware bags in order so I can grab them as needed and then put the leftovers back. Otherwise it’s too easy to misplace them. I think (haven’t finished yet so can’t be definitive) that if there’s a difference between left & right or top & bottom they note that in the instructions (often in the little callouts pointing to the difference so read all the small print and part notations in the pictures), otherwise two of something will be interchangeable but will still need to be oriented properly.
I’m just taking it slowly and rechecking every step before moving on to the next step. Figure it may take longer but probably not longer than putting it together wrong and having to disassemble and put it right
You haven’t really given much to expand on. Why not take a moment to post a couple of pictures of where you are at, and specifically what pieces you are having trouble piecing together?
Dude wants paint by number.
I’m sure u know everything about anything except for what ur doing now?
Your sentence structure is infinitely more confusing than the frame assembly instructions.
That was one part of the instructions that I struggled with for whatever reason too…took me turning off my music, laying the parts on the work bench as they were pictured, and re-reading the instructions very slowly like 5x…and then suddenly it all clicked and I got it all worked out.
Pictures and/or some more specific details about what exactly has you confused would be helpful.
