Got my CF Pro 99% assembles today!
I have to add the drain fittings and then it will be assembled. After thinking about it a lot I decided to weld the table seam together. It was much simpler than I thought. I thought about adding water and other things that I saw here on the board. I didn’t bother, I bolted it together and used the pulse feature and jut went at it. Very little heat was transferred to the part. You can see that in the pictures. While I’m not a great welder and these aren’t pretty I think these will be water tight.
So far I’ve been very lucky, it worked first try!
