Check the wires going to the thc box from plasma cutter and to fircontrol box. I had a similar error and did not have one of them plug in. I had unplugged it and forgot. Be it’s your first cut make sure they are hooked up correctly.
I just checked again. I even checked to make sure I soldered correctly. Seems to be right from what I’m reading. It fires then runs for the pierce delay time, then shuts of and fire control states no current.
do not use the override on the Firecontrol…go into your sheetcam or fusion settings and do it there…
if you start at .5 and use FC to increase by 200% you barely making it up to 2 seconds…
it needs to be in the post process to really make a differance
Chasing the pierce delay will not help you. You need to figure out why you are not getting voltage in THC when the torch is firing. Have you gone through the troubleshooting guide linked in your 0V THC Test?
Please use the THC Troubleshooting Flow Chart linked here:
