Is there no way to edit what you’ve entered into FireShare? I wanted to add some additional details, but it only gives the option to “Delete”.
Not that I’ve found. I put my shelf bracket up there - I had same question…BTW, saw your post on the water shield - downloaded - going to play with that today! Thanks!
I think only way would be to copy out your text, delete it, create new, paste in text so you don’t have to retype everything + changes and re-upload files.
Seems odd for sure. NOTE: With the DXF I uploaded, you may need to set the ratio 1:25.4 when importing.
