I was wondering how you use the the files that
are not marked cut ready in file share
You use Fusion or Sheetcam to create tool paths and post process them into g code that Firecontrol can use.
If you want to do anything other than cut things other people shared, you will have to learn the workflow. The process is shown in the support section of if the Langmuir website.
Is sheet cam easier to
Use than fusion 360
Sheet cam is pretty easy to learn. But still takes time
Sheetcam is pretty easy to learn, but it’s not design software.
If you want to design your own stuff(and you definitely will at some point) you will need to pick a design software and invest the time to learn it.
