I’ve had this on 1/8" and 3/16" material where the preview in Sheetcam and what’s drawn on Firecontrol shows cuts and then rapids. Occasionally and seemingly on bigger files it will not turn off the torch before a rapid move across the part.
I did some searches but didn’t see anything similar. Am I the only one with this? It seems random. I didn’t try cutting this again as I’m not excited to wipe out otherwise good 3/16" steel. Over the past year, I’ve had it happen probably a half dozen times.
That would cause it to only happen once in a while? I’m not a power user cutting hours at a time, but I have a fair amount of time with the setup and it only happens occasionally.
You could accidentally hit the button maybe… another possibility would be the relay being lazy or sticking in the in position. Most common is the 2t 4t button.
If you have it in 4t, it could cut some loops at low power and skip some, depending on how many cuts per piece.
If you had a Titanium plasma cutter, I would say it’s the plasma cutter shutting off late. I haven’t heard of any cases of razorweld machines doing this.
Is it cutting on the full rapid or just a short cut?
