that was easy got it set up no problem
I drew some thing up in fusion a washer just to play with the table and when I open the file in fire control, it’s outside the cut window for the table.
I can’t figure out how to move it inside the cat window. Any insight out there?
What am I missing?
Click on “set program origin” and click on the green box in the upper left corner. I’m assuming that you have limit switches, or this wouldn’t happen.
yes i do have limit switches i did that but it wouldn’t let me move it.
it gives you a box on the 4 corners
Yup. Click on the box in the upper left corner. That changes the origin point to that corner and will place the part on the cutting area.
Alternatively, you can jog the torch away from the corner far enough to fit your part and hit “zero all axis”. Then your part will be placed where you have the torch.
Thanks I will give it a try.
