Got ya. You can post codes so we can look at for you. some reason I wonder if some how it may be missing. My thinking is if it was a voltage lose it would stop completely.
This is the code for the file I am having trouble with.
(v1.6-af)
(Machine)
( vendor: Autodesk)
( model: Crossfire Pro)
( description: Langmuir)
G90 G94
G17
G20
H0
(2D Profile2)
G0 X3.6865 Y-0.0342
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
G0 Z0.15 (Pierce Height)
M3
G4 P0.7
G0 Z0.06 (Cut Height)
H1
G3 X3.8805 Y0. I0.094 J0.0342 F22.
G3 X3.6195 I-0.1305 J0. F22.
G3 X3.8805 I0.1305 J0.
G3 X3.6865 Y0.0342 I-0.1 J0.
H0
M5
G0 Z0.
G0 X4.874 Y-0.0342
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
M3
G4 P0.7
H1
G3 X5.068 Y0. I0.094 J0.0342 F22.
G3 X4.432 I-0.318 J0.
G3 X5.068 I0.318 J0.
G3 X4.874 Y0.0342 I-0.1 J0.
H0
M5
G0 Z0.
G0 X5.8135
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
M3
G4 P0.7
H1
G3 X5.6195 Y0. I-0.094 J-0.0342 F22.
G3 X6.3805 I0.3805 J0.
G3 X5.6195 I-0.3805 J0.
G3 X5.8135 Y-0.0342 I0.1 J0.
H0
M5
G0 Z0.
M30
(PS21)
No retract?
What I just seen what is your safety clearance
I’m thinking this might be my screw up…
I need to get back to a real computer.
No way!!!![]()
Hard to work with unfamiliar stuff sometimes.
Safety clearance?
What’s the file name of that g code you posted I’m trying to look it up
Safety clearance is setting telling z axis to raise to a set specific position before moving. G codes showed 0 which was touching metal.
knick test 6
knick test holes aug 29 22 with retract and small lead out v1.f3d (130.6 KB)
knick test hole aug 29 22 with retract and small lead out.nc (1.2 KB)
I started and new fusion file from scratch and it seem to be good now . I am not sure how the retract was omitted ? it must have been when we were toying with the idea of it retracting enough to go over the leg of the channel.
here is a the revised code and f3d
v1.6-af)
(Machine)
( vendor: Autodesk)
G90 G94
G17
G20
H0
(2D Profile1)
G0 X3.4927 Y-0.0239
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
M3
G4 P0.7
H1
G3 X3.6285 Y0. I0.0658 J0.0239 F22.
G3 X3.3715 I-0.1285 J0. F22.
G3 X3.51 Y-0.1281 I0.1285 J0.
G3 X3.6269 Y0.0199 I-0.01 J0.1281
G3 X3.6018 Y0.051 I-0.0395 J-0.0062
H0
M5
G0 Z1.
G0 X4.6802 Y-0.0239
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
M3
G4 P0.7
H1
G3 X4.816 Y0. I0.0658 J0.0239 F22.
G3 X4.184 I-0.316 J0.
G3 X4.51 Y-0.3158 I0.316 J0.
G3 X4.8154 Y0.02 I-0.01 J0.3158
G3 X4.7932 Y0.0533 I-0.0399 J-0.0025
H0
M5
G0 Z1.
G0 X5.5073 Y0.0239
G92 Z0.
G38.2 Z-5. F100.
G38.4 Z0.5 F20.
G92 Z0.
G92 Z0.
M3
G4 P0.7
H1
G3 X5.3715 Y0. I-0.0658 J-0.0239 F22.
G3 X6.1285 I0.3785 J0.
G3 X5.74 Y0.3784 I-0.3785 J0.
G3 X5.372 Y-0.02 I0.01 J-0.3784
G3 X5.3938 Y-0.0535 I0.0399 J0.0021
H0
M5
G0 Z1.
M30
(PS21)
Thank you I will give this a try
That did it worked like it should. Top side dross was near perfect bottom side had more than I would like and did not chip off easily. Now I need to try some different settings.
Thanks guys
That’s good to hear you’ll have to experiment with the razor weld settings. Try 5 in per minute faster and see how that affects the cut.
Also with it being painted on the back side it will ball more so than clean material.
I did remove paint and that did not seem to make much difference.
I will add 5 IPM to speed. So in fire control that would be roughly +20%?
21ipm @ 20% = 4.2ipm so 25.2ipm total
yes that seems good to start
