Been using the pro with no issues until now. Started fire control today and no connections to my table.
Motors change sound when usb is plugged in but fire control does not see the table.
Have reinstalled firecontrol with no change and deleted the folder in users.
take off the cover on the control box, plug in the usb cable to your pc and control box and see of the red/green LED lights up on the main board and THC.
As others have said the first thing id recommend is trying a different USB cable. If that doesn’t resolve it shoot us an email and we’ll see if a new MCB makes sense for you.
I am having the same problems, Followed all of the suggestions. Nothing has helped. This is a brand new system that doesn’t have any corrosion. It connected the first day I powered up and did some manual jogging. Came back to do my first cut and make a part and now this…
I am also having the same issues. The computer doesn’t see the machine to give me the option to update the driver manually. Was there ever a solution found?
Yes. Ran the break in, made test cuts and 1 bottle opener. Designed parts for a job I have pulled into the shop and no connections.
All lights are green except the red on thc.
Tried different cord.
Different computer.
Cannot see the device in device manager to update drivers.
If drivers are the issue, you have to manually install the drivers without the table USB plugged in. After the drivers are installed, Windows should recognize the Table and the THC when USB is plugged back in.
