I’m not an owner of anything yet. Not sure I want to pay $360/yr for Fusion 360. Is Fire Control sufficient?
I may not even be asking the right question(s). I am computer savvy and understand cad/cam in the design of golf courses in 3D. I’m sure I could learn Fusion, but $360/yr seems a bit steep… maybe not.
OK…Firecontrol is only a program that Langmuir uses/developed to actually run the Crossfire table…much like Mach3…it onkly tells the table what to cut.
Fusion360 is a CAD/CAM software…meaning it is a design software (CAD) and then it also can take the design and convert it to g-code…a TAP file…this is the CAM part.
there are many design softwares out there as you may know…
the only other truly supported CAM software is sheetcam…available cheaper through Langmuir…but is is only the CAM part.
I use Inkscape (free software) for 90% of my design work, I also use AutoCAD for the remaining…but I use Sheetcam for my CAM work…and then load the final TAP file into Firecontrol to cut.
