I was running an older version of firecontrol and finaly got an update and now im having this issue where i cant see the whole fire control screen!??!?!
That is a really old 4:3 aspect ratio monitor. I’m sure the current Firecontrol is set for 16:9 aspect ratio and that’s why it doesn’t fit on the screen. See if you can change the display resolution in your computer settings to get it to display correctly.
I figured it had something to do with it. I’ve messed with the resolution but ill look into the aspect ratio thanks for the reply!
Software should be set to a window size not a platform. I have noticed you cannot manipulate the window, it is either full screen or closed. Rookie software writer.
