I’m running a primecut60 . Cutting 16 gauge at 30 amps using .08 tips in an IP60 torch. Of course I read that most people are cutting this at 175-200 ipm. My question is about very fine detail and small cuts. if you were going to cut something as small as a 1/8th hole how much would you slow the cut speed down for that ?
I wouldn’t try to cut a hole that small (or smaller that 5/16 inch for that matter). The pierce hole (and hardened steel) will mess up the accuracy. If you want an accurate hole ‘drill’ a ‘peck’ to mark the center of the hole and drill it out later with a real drill. There are plenty of examples on the forum. Search for Drill and Peck…
True for mechanical parts but okay for artwork where the work hardening of the hole edges and any mis-sizing due to sloping sides to the cut won’t really matter. But for anything you’re looking to put a bolt through the peck & drill approach is the way to go.
Yeah Im referring more to art work. Just trying to figure out how much to slow down for tiny details.
These were cut out of 16g cold rolled with a cut60 at 100imp, 30 amps with 40amp sheilded consumables. Not super detailed but some parts got pretty tight.
