Hello guys,
Ive got my machines dialed pretty well i feel like but i have issues with detailed cuts. Where can i find 6mm tips for the cut 45? I need a tighter kerf width. Can i use the hypertherm consumables on the cut 45?
Thank you in advance!!
Hello guys,
What brand cut 45 do you have as there are many.
Razor cut 45
If your using a X45 machine torch you could try these Hypertherm consumables. If its a hand torch the Hypertherm retaining cup won’t work you will use your retaining cup.
420120 electrode
420118 tip
420211 swirl ring
420114 retaining cup
420115 deflector
Or PM me and I can set you up with a fine cut kit.
Its a machine torch i’m using, thank you very much for the info!
Are these parts considered the fine cut kit you were talking about? If so would you recommend using them on 16g mild steel?
The part numbers are for Hypertherm consumables and yes you could use them on 16 gauge.
Thank you very much for the info
