Feeds,Speeds and power
I think I have watched to many You Tubes and am getting myself confused. Will Sheetcam control the feeds and power on Fire Control? Of does fire control set these? Thanks
You set those values in CAM, you can tweak them in FireControl with the ovveride buttons.
sheetcam will allow you to create tools(settings) for each type of material you want to cut.
each tool you create will allow you to control speed, height, direction…
then sheetcam creates a TAP file which tells FC the basics and the shape and such.
as Daniel said…you can tweak the speed and pierce delay in FC.
you have to play with your Plasma amperage yourself…and in some machines…you adjust the air pressure also
