Feed Rate issue
Mach3 isn’t recognizing the feed rate when I upload the code. I’ve verified in Fusion that the feed rate is there and correct. it worked well in the demo mode, this problem is occurring after purchasing and installing the full license.
@pony.moto Can you elaborate on what Mach3 is doing? Is the programmed feed rate being ignored?
Did you inadvertently override the feed rate in the UI (center of the Mach desktop - you can enter a number or pull a sliding bar up or down)?
It was me… When I uploaded the code, I didn’t see the correct feed rate in the controls. As soon as I turned on the the table and the plasma cutter, it appeared.
…And it all worked great!!
Thanks for circling back!
