I’m having problems with my feed hold. If I use feed hold it randomly when I hit cycle start will go nuts and run all the way to Z+ or Z- or Y- or Y+ end stop and try to keep going. Sometimes it does all of them. Sometimes it just makes a circle and goes rite back to cutting. When it hits the limits it will cut but will be way off from its path. When it goes into this mode it makes some funny noises and does everything in slow mo. I’ve emailed langmuir and haven’t heard back figure they are too busy.
I had never heard of “feed hold” so I had to google it. Apparently its a Mach3 thing and my google search showed that this problem is common. It seems to be a Mach3 problem and not a Langmuir problem.
