I am super new to CNC plasma, so please forgive me if I’ve overlooked something obvious. I’ve tried searching here but haven’t seen this mentioned, but I may also not have my search fingers down just right!
Today I was using my CF Pro to rip some 1/4" plate. It is extremely useful to use the table in this manner; it saves me quite a bit of layout, and I don’t even have to get out the clamps and fences and the saw and all the PPE!
However, squaring the sheet to make good cuts that maximize sheet use is a bit time-consuming. I need to mark out my path, jog to the start and get the torch set, then jog to the end and make sure that I’m still on my mark, then jog back to the start again and make a quick “straight cut” program in FireControl.
This does totally work. So does using the software to set a low jog speed and manually fire the torch and then just holding down the jog key.
However, it would be really great to be able to just flop the sheet on the table and go to a point and say “this is X0Y0,” jog to the end (without squaring the sheet) and say “this is (for example) X32Y0, please cut a straight line between these two points.”
Maybe this feature exists and I’ve overlooked it. Again, newbie. Also super-new to Gcode. However, it would be really handy to be able to do this and not worry about squaring the sheet. Similarly, it might be nice to just have a manual field for jog speed so instead of choosing from 10/50/100/200/300 I could just enter a value – say, 20ipm – and do a quick cut that way.
It’s 100% possible I’m just not using the software to its full capacity but these would help extend the already significant functionality of the table.
Thanks!
