F3g to DXF or SVG
Anyone care to change theses f3g file to DXF or SVG
I am going to try deepnest
Thank you
Rivertown angle bracket 4x10 x18ga v4.f3d (131.9 KB)
Rivertown angle bracket 7x13x18ga v1.f3d (126.7 KB)
I’ve tried deepest a few times. I was not impressed. I played with a bunch of the settings and just waited forever for it to kick out some arrangements for me. One nest it couldn’t fit them all on my sheet, at least I didn’t want to keep waiting and I just manually nested it all.
It doesn’t work for me either. I gave up on it for now.
Can I manually nest them in fusion without the Add-on?
I use the FireControl nesting. I realize you want to make as many out of a sheet as possible.
That program will put a crap load on a sheet but will not optimize it like your wanting
I have done it in firecontrol also, but these would work out much better optimized
I get it. Deepnest just has not worked out for me.
Maybe some of the other rocket scientists can help.
Can you send me a picture of what they look like it is also possible to do nests in sheetcam. I can’t now but possibly later today. I would definitely need dxf file.
My computer has issues with f360 the only way I can get it to open a file is to upload it in the cloud .
I can no longer export as a DXF or SVG. Let me play with it and see what I can come up with
I mean; deepnest DOES work. It just takes a while, and the nests were not to my satisfaction. To increase the number of potential rotations and other options increased the nest time exponentially.
But I just nest in my svg program and it’s cake. Can’t you just copy and paste in fusion and rotate stuff close together?
Deep nest is trying right now, copy and paste is next. Remember I am a fusion failure!!! :rofl: :rofl: :rofl:
Oh yeah, I don’t use fusion either. I’m all SVG drawings.
15 mins and deepnest just keeps spinning. must be something wrong
I don’t know if this came across the right way but there were no sketches so I projected the flat pattern to a sketch and converted in Fusion 360. (Fusion 360 needs a sketch to save as a DXF file).
Rivertown 4x10Chelan.dxf (3.5 KB)
Rivertown 7x13Chelan.dxf (3.3 KB)
Edit: I changed the bend lines to construction lines:
Rivertown 7x13BendConstruction.dxf (3.4 KB)
Rivertown 4x10 BendlinesContruction.dxf (3.6 KB)
That’s what it does for me, too. Just sits there spinning.
Jim
Thank you I did not know it had to be a sketch. I will take a look.
I was able to just get it done in firecontrol.
I was able to rotate and nest it just like I wanted, it was pretty easy for just 4 pieces. I stumbled around in fusion longer and got no where
Good!
You know I like to try these things anyway just to learn. I found out that Deepnest does not like construction lines. It separated one of the objects into two pieces. I am not sure either file would have worked with the way it turned out: you would have had to delete the bend lines all together.
So what I am saying is: you would not have been successful with the files I converted. :stuck_out_tongue_winking_eye:
I would think arrange in Fusion should be of help. It might take some tinkering with thefile, but I’ve had good resuts.
I don’t have a paid subscription anymore so that’s not an option for me.
Nope, it’s just ugly slow. Even if I wait, I find I can nest manually just as good and in a lot less time. Try leaving it overnight and see if it comes up with something better but I’ll bet not :slightly_smiling_face:
As @brownfox noted, the time grows exponentially as it deals with variations.
