I could not get your toolpath to work so I deleted and started over.
Just deleted toolpath, so the setup is fine. You will still want to check my lead-ins/lead-outs. I was just trying to see if I could get the outer contour cut. VFD Mount v1ChelanJustToolPathChanged v1.f3d (220.0 KB)
Perhaps Tin or Terrance or someone else would take a look at the original toolpath to try and figure out what is going on. I can’t figure out what it doesn’t like.
2nd Edit: Yours works now. I just changed “Compensation” from “In Computer” to “In Control”, but I don’t know the consequences of changing this. Reading the help instructions, it says that you will need to enter information later to allow for proper clearance for the kerf width. Above my pay grade.
Very odd. I looked at the original toolpath, and was able to get it to select the outside perimeter by turning off lead in / out. However, I was unable to change where Fusion wanted to place the leads regardless of what I tried. I suppressed the original toolpath and created another, which worked fine.
I also noticed that the original toolpath had an issue with the bend index on the upper right ( at the corner.) Didn’t seem to want to complete the path. VFD Mount v1 v1.f3d (234.1 KB)
This is what I hate about Fusion. Unless you are using it daily stupid stuff like this pops up and is hard to figure out. I never know if I will find the problem or it’s better just to start over.
That is what I kept thinking that there was some clearance of the cut path or lead-outs/lead-in but why did it allow a new tool path with the same setup.
I found the problem, although I don’t know why Fusion 360 was so fussy.
For the cornering on the outside, picking “Keep sharp corner” was rejected but if you pick the other two options, no problem. The funny thing is that it is not a “sharp” corner!
Also your work flow for the notch and the holes, I would do it through a sketch with in unfold tool instead of doing it through the flat pattern. It will show better in the timeline.
