How do i edit the thickness of a previously saved extrusion
I assume you are talking about generating gcode from body, Fusion does not care how thick something is if you are only doing a 2D profile cutting. It only uses the face in Manufacturing.
But if you are really doing modeling for 3D printing or sheet metal that is a different matter.
It is rather easy to change the extrusion dimension:
Find the extrusion event/feature in the timeline
Right click on the ‘feature’ and select “edit feature”
Edit the thickness of the extrusion (‘distance’).
Click OK. Done
Ok thankyou i was worried it would matter
