Excel files to Fireshare?
Does anyone know if you can upload an Excel file to Fireshare?
I came up with a simple to use spreadsheet for determining the dimension and bend angles needed to make the parts for Barn Stars, based on the desired diameter and center projection.
If it doesn’t, you can add an additional “.jpg” to the end of the file name and advise people to “remove the ‘.jpg’”
(or use the extension of another file that fileshare accepts: dxf, svg)
You might consider posting a topic in the forum as any submissions in FireShare cannot be edited. You might want to revise or add more to your offering/listing.
