I just got my Everlast machine and I was wondering if I am supposed to use the consumables it came with for only hand cutting or can I use them for CNC as well? It came with a cut guide that keeps the tip off the surface and the nozzle is exposed. Should I buy the nozzles and shield setup for CNC or do I just remove the training wheels thing and set the CNC for 0.060" above the surface. I will be using a THC as well. When do you want to use the shield? Do you gap it 0.060" when using the shield? I see the nozzle is retracted inside the shield in the pictures.
I just don’t know what to get for the torch before my CNC arrives.
