Everlast Plasma Cutter
anyone uses the Everlast 52i or 62i cutter for the Pro table? Heard there may some issues with compatibility.
That’s news to me. I’ve been using the 52i for a while now.
There is none… Hook it up for raw voltage and your all set. I have an 82i and has worked perfectly since new.
If you plan on cutting signs make sure you get the 60 amp torch.
is that a machine torch? and whats the reason for the 60 amp torch? and do you run the THC?
Yes i do run THC control. The ptm 60 machine torch has nozzle sizes that can go down 30 amps or so. Just don’t buy
cheap knockoff consumables.
I don’t cut many signs, but i can .
I’ve cut 1" steel down to 20 ga.
I keep both torches the 60 and the 80 for my 82i.
Some guys complain that the fan runs all the time. Its easy, just turn it off when your finished. If you buy one there are many guys here that can help you with a accurate cut chart.
Happy cutting…
are fine cut tips available for the 60 nozzle?
Yes… you can get tips for down to 20 amps.
Just don’t buy junk Amazon knockoffs.
There is a guy on the forum Mechanic416
That has a plasma shop in Delaware. He forgot more than most know. He can provide you with original parts.
thanks, i’ve been reading his stuff. btw, is that George?
Yes mechanic416 is George’
I use the 52i as well.
