Hello everyone I just got in my Everlast 82i and I’m having some trouble with it I went to go cut a program and the first one was decent better then my razor weld but the second cut this machine was acting all weird. it started off good but then went to the next hole and didn’t fire then missed another hole but while it was doing the fire control was picking up raw voltage, I thought that was only for when the torch is actually on. but another time it started to finish the overall part but didn’t fire when it took off and all of a sudden it fired cant figure out what’s going on thank you for your help.
IPM is 40
Keft width is .045
Tip is 1.3
Air pressure is 65-69 when cutting
Amps is 75
Pierce delay is .5
cut height is .06
Pierce height is .095
@Ozzywelding im sure others will chime in for sure but your torch is clamped too low the bottom.clamp should be above the lower section as it causes the blowback tip to bund when clamped low.
Okay so I just moved the torch to the picture’s location and I was reading some where on here that the nozzle is supposed to spring back a little well I noticed when I loosen the outside nozzle I have spring back about 1/8” but when it’s hand tightened it it’s got maybe a 64th movement in it am I supposed to leave it a little loose?
@Ozzywelding the nozzle is the outer metal portion with the orifice in it…the electrode is the inner metal piece…do you mean you expect to have play or springback in nozzle or the electrode…the electrode moves when firing…the nozzle is fixed and should be secured by the retaining cup…the outer grey plastic piece that you screw on last.
Well I was under the impression when everything is put together the nozzle would have spring back when I push on it it a little bit I’m guess it’s not supposed to have any movement when it’s all together
The nozzle they referring to is inside the cup.
You would screw in the electrode into it. With the cap off you should be able to push up on it with your finger and it should snap back.
Correct. Just keep the torch holder clamp up above the Internal mechanism. Happy cutting pal. By the way the electrode in the picture look trashed. Pretty blue color.
Really that maybe had 15 pierces on it and when I moved the torch and clamp all the way up I now only have about a 1-1/2” I’ve movement is that normal also I had 1/4” plate on the table when I measured
