Everlast 82i Air issues
Had an issue with my 82i , went though Everlast got a replacement solenoid and a control board. Installed it today and now the just freeflows through the torch. Pressure display on cutter will only show like 43psi. Anyone had a similar experience or could maybe shed some light on this problem. Thanks in advance.
Maybe something is stuck inside the selenoid.
Here is a service guide for the selenoid.
Just click on the Adobe link. Unsupported Browser | Adobe Acrobat
I will double check it. It is a brand new one, but i guess it would be possible.
Solenoid installed backward letting the air bypass.
I thought that as well, flipped it around and I get 0psi on the display.
The air solenoid out goes to the torch connector. The in has one hose from the regulator and the other hose to the air sensor. If its installed correctly and you have no air pressure on the display then there is no air coming from the regulator to the solenoid.
I have been lucky so far. I have had my 82i for five years without any issues. I would buy another in a second. I keep a solenoid on the shelf though.
It never rains when you have an umbrella…:grin:
Here I am again derailing a thread. Sorry @Knick
At least I haven’t gotten @ChelanJim involved yet.
Thanks for the info! I will definitely double check.my connections.
I have had mine for 3 and this is the first problem I’ve had. When I first got it I didn’t have the driest of air. Bought an air dryer and it made such a difference in quality of cut. I appreciate the input.
