I have searched this forum and have seen conflicting views on the proper hook up. I purchased the everlast 62i with a machine / pencil type torch. It does not have a firing switch on the torch. My question is do I use the blue connector plug provided with the unit and only wire to pins 1 and 2 start/stop that plug into the Langmuir controller? This is not the hand held torch and I am not using the THC module.
Yes. Pins 1 & 2 to fire the torch.
if you have any questions…not to worry…we here will help…
I have a 62i and a Pro table…
Pins 1 and 2 as noted by @TinWhisperer …or as we refer to him as Manual-Man…
so there is a cable with the kit for torch fire…it does not matter which color goes to pin 1 or 2…
now when you go for divided or raw volatge…you can try the pins on the CNC port…but if you have issues later you might have to switch to the RAW direct voltage inside the machine…
