I wired my 62I to RAW power inside the PLasma, I cant find anywhere that states where to plug the trigger plug to if using the CNC port in the back of the PLasma and wiring on the trigger wires to pin 1 and 2? Does the CNC trigger Pigtail go to the VIM box in the DIV input port or do I plug it into the CNC tables electronics box that has a port that states Trigger on/off? It will plug into both.
It goes in the control box where it says “torch on/off”.
If you are using raw voltage, nothing goes in the DIV input spot on the VIM.
The Red and Black wires from raw voltage go to the color matched spots on the VIM and then a cord gets connected between the PV output on the VIM to the THC input on the control box.
(Edited)
You are correct, sir. My mistake. I have edited my post to reflect that.
I got it working. Thanks!
