I’m going to assume this is backwards, how do I get it out without ruining the swirling or damaging the torch?
That’s not the swirl ring. I don’tbelieve. . It looks smashed into the torch head. Screw in an electrode and push it in with your finger. It should push in and snap out.
That piece is stuck in there like hell, I’m going to have to replace it because getting it out is going to ruin it. Is the swirl ring up inside there? I’m completely new to the everlasting unit. Obviously
I’m not sure at this point. I have never seen that before.
Update. The old swirling was still on an old consumable, I popped it back in the torch and we’re good to go, really simple. Sorry about that one.
Learning the hard way.![]()
When your ready to upgrade to quality consumables let me know.
Bigdaddy,
I’m planning to upgrade my plasma setup this weekend—from just using the CNC port connector to running THC along with start/stop.
So just to confirm—you’re only using pins 1 & 2 for start/stop on the CNC port connector, and then for THC you’re tying into the raw voltage connection inside the unit like shown in your photos?
Thanks,
Micah
Yes, pins 1 and 2 are start stop. Raw from inside the plasma cutter.
