I have been using my Easy scribe for the last month. Went to cut today and torch not firing. I have a Everlast 62i CNC. Have it wired to raw voltage, ground clamp on material. Air pressure 76 going in to plasma cutting. It has 73psi when air is going through plasma cutter. I hit torch fire, can hear relay kicking in and air start flowing. The torch light will light up on fire control, put 2 sets of new consumables in and still the same. I have tried everything I can think of, I’m out of ideas.
Have you confirmed that the torch plug in the control box is engaged in the port? Can you jump out the torch plug with a paperclip or something like that to see if the plasma cutter will fire?
The end of the torch that screws into the cutter is called a Euro connector
Twist it and pull it off and check out the connections. Should be 4 pins two are not used and two go to the pilot arc.
I took it apart and everything look good in there. Nothing was loose that I can see or feel. Put back together and still no fire. I sent George an e mail.
Lots of responses so I might be echoing something here.
Manual firing of the machine doesn’t work?
Switching torches (if available) do anything?
Consumables were verified as working IE correctly installed, undamaged, torch head prongs sticking up making contact with the retaining cap, electrode springs back when pushed in?
