I only sell the 1.0mm/50 amp cuttings and I think Everlast sells a 1.0mm/50 amp tip as well. Now you may find a smaller cutting tip from a Chinese seller.
I would recommend getting a PTM60 machine torch that way you can use it for thinner metal, as there are cutting tips from .065/20 amp to 1.1mm/60 amp.
And you can get a Chinese IPTM60 torch as they are cheaper then the ones I sell.
Youâre not going to make any friends here belittling George or any of us on the open forum.
No problem peddling your wares on the Forum just try to be polite to other members while you do it.
And as far as resellers go youâre literally reselling hypertherm retrofit kit with the Everlast torch plug end on it and reselling a hypertherm PowerMax sync torch adapter with it.
Check this out guys⌠I put Amp steps and a B&W hitch on a Ram truck⌠Yup Iâm a manufacturer now. Donât go to the Toyota dealer⌠Come to me with any questions you have on Toyota trucks.
