I have a new system. Have had some good success, but keep getting this error message with Sheetcam: cut start is above rapid clearance plane. I do not have the z axis on my machine, and have the height settings pierce height, plunge rate and cut height set to 0. Any suggestions on what to check? Thanks, JoeO
Do you have your x axis zero set to top of work in sheetcam? I’m just guessing here.
I think I fixed it by making the rapid height higher. At least I think this may be what I did. Thanks for the quick reply and help.
Regards, JoeO
hello my friend I’m facing the same problem, can you tell me how to fix it?
I changed the setting for rapid height to a higher value, and it seemed to fix the problem.
