Hey Everbody,
i´m looking for some electric details. I woud use the XR in europe 230V power grid. Have anybody some details about the internal power Supply ? Machine Controler, Stepper Motor Driver, … run the parts on 12V?
Thanks!
Alexander
Hey Everbody,
Thanks!
Alexander
Did you get this figured out?
Im looking to do the same thing
The electronics enclosure, which runs the table, can be run on either 120v or 220/230v. There is a switch on the enclosure to select which power input you are using
Everything in the electronics enclosure runs on DC power. The mains power input is only to power the DC power supply inside the enclosure.
Ohh i thought only the pro is selectible and not the xr? Interesting.
Thank you
I don’t have the XR, so you may want to call support to ask. I can’t imagine that they use a different power supply for the XR, though.
@TinWhisperer can you confirm that The XR control box can run on 220/230v or is it 120v only?
I think the XR is 120 only.
There’s no external switch from 120 to 240 on the power supply box itself. Also it’s listed as line 1 and neutral for the input power.
