I’ve been cutting on this table a long while now, but recently have been having some issues, see pictures below!
Used to have nice and clean cuts but now some dross has been bridging the backside of the cut. It’s not hard to clean it off but would like to limit it.
I’ve tried a lot, usually cut my 14g at about 160ipm at 35 amps
I’ve tried going up and down in amps, and even decreasing cut speed, as well as new consumables but doesn’t seem to help.
Tried changing the desiccant in my water traps too
Off the top of my head and in no particular order (not had my coffee yet):
Check the work clamp for proper contact. Work clamp should be on the material, not the slats. and, electrical connection integrity at the work clamp (bolt and terminal).
Check air pressure. Not only static but dynamic (about 10 to 15% drop at the machine’s gauge when torch is firing)
Maybe something is up with the sheet of steel. Seen a few oddball posts about weird performance despite nothing changed but the material. Have you measured it? Maybe it’s thicker than you think,
Not sure if you resolved your issue. I will chime in for future researchers. For 14 gauge, 160ipm seems to be on the fast side. What I have learned is to read the sparks. By that, I mean the sparks when cutting. If you get large rooster tails, and a lot of sparks above the material, you are running too fast. At the proper air pressure and speed, the right amount of material will be removed and the sparks will be more underneath. Also, did you check the condition of your swirl ring?
