Plasma was cutting. No will not fire torch. Shows plasma on, but Dwell light flashes and no torch fire. When torch was firing, the plasma was cutting the outline before the hole. Unchecked the “reverse axis” in config, per suggestion of another feed. Now torch not firing at all. Tried to reinstall software, getting the following message:
Attempt to run drivertest.exe and says no driver installed. Verified wiring on plasma cutter is correct. This is for a Crossfire system with a Lincoln Tomahawk 625 plasma cutter.
