I’m experiencing drift when patterning. I’ve narrowed it down to only new files that have been saved either in fusion using FireControl post-processor or if I saved it after making changes in fire control itself.
The files seem to be corrupted in a way that is only noticeable when patterning. The cuts are drifting to the right and the outside cuts are not lined up with the inside cuts. It is consistent and only happens on files that have been saved since mid -September. Everything saved prior to mid-september still cuts perfectly.
I have verified I’m using the current version of the post processor in Fusion and of fire control itself and have since uninstalled both and reinstalled them with the current version and still having the issue.
It could be coincidence with the selection of files chosen and the area you’re cutting on the table.
Using the pattern feature simply copies the movements of your initial item, therefore has no way to “change” any such movements.
You could have a coupler slipping when it gets to one end of the table, some slight binding, added play, etc but there’s no way a file’s data can change outside of specific functions.
Anything change in mid September? This is what I would focus on.
So if outside cuts don’t line up with outside cuts, are they off by the same amount beginning of the pattern as they are at the end? If so this would rule of a slipping coupler.
Are the vectors defining the design perfectly flat in Z? You may not notice it in the view, but a tilt in the plane will generate slight shifts in the other two axis when patterning.
