Morning James,
I have setup your tool set and added the 1/2 second pierce delay to each tool based on the HT manual and what you had. Did you need to do any adjustments to pierce height?
What we have going on: touch goes down, touches material, goes back up, then torch fires, goes back down to material and starts to move. It leaves a hole in metal. I’ve been working with lead in. Based on videos I’ve been watching they say to select ARC and set the measurement. What do you set your lead in at/ lead out? Do you change pierce height from manual settings? We’re just trying to get tools setup correctly.
HT45 machine.
We’ve been using 14g metal to test things.
