5857 Bridgetown rd Cincinnati Ohio 45248
I feel dumb because I cant figure out how to change from DXF to STL. Can someone send it, or upload to thingiverse? Looks like the ones on there are larger.
In your file system select the file.
Right click and select rename.
Change the file extension from *.dxf to *.stl
now you should be good to go.
Are you using windows?
yes, windows. Im not seeing that i can change the extension, just changing the name to Dimple die v2 bottom.stl didnt seem to do it. im sure it is easy and im making it more difficult than it needs to be.
you may have to active your ability to see the extensions in the renaming window.
Here are the steps for that.
How to Change File Extensions in Windows 10 Correctly.
Step 2 in the link " Alternatively, you can also click Options on the uppper right corner to disable the Hide extensions for known file types option from File Explorer Options in Windows 10 by unchecking the option."
that did it, thank you so much, And thank you for the super fast response. Printing now.
