Detachable chain sprockets
A friend brought me a idler shaft off a conveyor asking if I could time the sprockets ( cut new keyways). One of his chains kept jumping off the was thinking the sprockets wasn’t in time. Here is what I noticed.
One was wore way more than the other. They are detachable sprockets so they are made sloppy. He had tried heating one to get it off. That doesn’t work with cast iron parts like this so here is what I had as soon as I pressed on the shaft. These are 9 tooth sprockets which the ones I found wasn’t cheap at all.
Made one test cut on some 3/16.
I used what I had in the scrap pile to make the hubs( a 1.750 grade 8 bolt), some AR400 .5 plate for the sprocket and here is where I am now.
Now i think I will be making a new shaft this one is in pretty bad shape.
Nice work!
Thanks @Knick this was a fun project. I would rather do things like this anyway. The hardest part was broaching the keyways in a manual press.
That is an amazing replication. Great job Phillip.
Thanks @ChelanJim I used sprockteer to create a dxf. I did need to modify the OD a little. Roller chain sprockets are a little different than detachable chain ( detachable sprockets seem to have a more straight tooth). The chain seems to accept the sprockets well enough.
