I am having some trouble with the detail and accuracy with my cuts. My cuts lose detail or do not match the displayed image in FireControl. Usually one side seems to cut fine and the other starts losing curve, squaring off or adding points to the curves. I was hoping to get some suggestions or settings I can focus on to correct this. The same result on both 16guage and 14guage. I leveled the Gantry, took off the casters and squared up the CrossFire frame with a square as suggested by tech support. Could it be interference if the control unit is too close to the plasma cutter?
Are these your designs? If not maybe they need cleaning up in CAD.
Most things downloaded need cleaning up.
How big are they?
Have you had good cuts before?
They are about 6 inches and the Texas State is about 21 inches. They are my designs created in Fusion, and I have not had a good cut yet, I am usually cleaning up the lines quite a bit. The expected clean up is easy so my speed is good.
Thank you everyone for your suggestions and support. After assuring that all the suggestions were addressed, I came across these two bolts that were just about to fall out and caused significant play on this bracket. It was the only thing loose and I hope it clears up my issues. I will give it a test run this weekend, wish me luck.
