Hi everyone,
I’ve been getting really nice cuts on different thin materials 16Ga and under (aluminum, brass, steel, stainless). See video for test cut coupons after dialing things in nicely.
However, I recently tried cutting 1/8’’ and 1/4’’ aluminum with some challenges.
I’m using a Hypertherm 30XP, finecut consumables with THC. My cut height is 0.030’’ (recommended by Jim Colt for the finecut consumables).
I have several questions I’m hoping to get some opinions on:
It looks like thick aluminum results in a lot of fine/fuzzy dust and dross. Is this normal?
I’m noticing excessive parallel bevel, but only on the X axis sides. Consumables are very new. I’ve noticed that the hand torch has a lot of play specifically in the X axis (pretty rigid in the Y) and I suspect this is causing the problem. What do people do to ensure their torch stays square anytime it’s removed and re-seated?
Pictures/videos attached here: https://photos.app.goo.gl/hkBKf1RubzffeTTX9
Thanks!
Phil
