Hey guys, need everybody’s help here. When running a program, my Langmuir standard crossfire will do a cut maybe two or three successfully then it won’t cut maybe one or two then cuts out again. The gantry keeps moving, so not sure what to do next I have wasted so much steel that I need help. Using a cut 60 on 16 gauge at 30 A.I’m relatively new at this so any advice you can give would be great!
Are there any error codes? It may be hitting its duty cycle cutoff. 30 amps is low, but it depends on the voltage from your electrical panel. It would be hard to trip on duty cycle at 30 amps. Unless you are using it plugged into 120v instead of 240v. It would trip at 6 minutes or so. Send us a picture of your consumables tips and your compressor output.
The error codes for the PrimeWeld CUT 60 (and similar standard CUT 60 inverter plasma cutters) indicate specific hardware, pressure, or electrical faults:
• E02: Temperature sensor is open-circuit or faulty
• E03: Overheating fault (allow the machine to cool down with the fan running)
• E04: Underpressure protection / low air pressure or torch/retaining cap safety trigger issue
• E05: Input voltage is too high
• E06: Output voltage is too high
FACTOR #2: Can your compressor keep up the 70 psi needed to cut?
Need more information: a picture of the consumables, air pressure setting, error codes, etc.
Where is your work (ground) clamp attached?
Is your Cut 60 set to 2t or 4t mode?
Do you have a powered Z axis or are you using a spacer to set torch height?
What size compressor do you have and what air pressure are you using?
