I know cutting galvanized is not ideal because of the toxic fumes but I do have a Miller PAPR that I wear when I cut it and the area is well ventilated. I generally cut mild steel but recently picked up 11 sheets of 17GA galvanized to upgrade my sand blast cabinet and build a powder coat oven so I have to cut it for these two projects. Does galvanized require any adjustment to cutting settings compared to mild steel? So far I have been running it with mild steel settings and it seems to be doing a decent job, not great but not bad.
I use the exact same settings as mild steel when I cut galvanized.
Galvanized is really no different…you might want to make sure you get a good contact with the clamp…but settings should be the same as same thickness of steel…
Real good to hear you are wearing and taking precautions when cutting for the fumes…
Funny you should mention the work clamp, true story…
So I’m filming all of this for my YouTube channel (video will post when the project is done) and I fire up the table to make the first cut and it gets about 6" into the cut and throws a “lost voltage reading” error and I’m thinking no problem I’ve got this it just happened to me this past weekend and was just time to swap tip and electrode. So I swap them out, regenerate tool path and return to zero to start over. Hit the start button, rub my hands together, here we go lets get these pieces cut so I can get to sandblasting my cuts for paint. About 6" in it cuts out with the “lost voltage reading” error again, now I’m worried because I know it’s not the tips and looking at the cut it wasn’t penetrating just gouging. I start packing my things up in there so I can head in and ask you guys what might cause it, then I noticed something sticking out under my table. Looked under the table and my work clamp is on the floor…it didn’t fall off, I flat out never even hooked it up and it’s all on video… This only happened I think because I’m cutting a 4x8 sheet so it’s hanging off the front of the table by 5 feet and I didn’t notice it like I normally would. The torch was only firing the blowback pilot arc which explains why it wasn’t penetrating that first 6". Anyhow, I thought it was funny at the time.
this is why I have a wonderful white board above my table…a check list to make sure I do not do something stupid…something stupid too often…
- check consumable condition and size for material
- check air supply
- check position of material…not blocking gantry
- check pattern layout…ZERO ALL AXIS…
- check material clamp
- check amps on plasma
asd so on…
flip it over…
trouble shooting
- check consumables…
He doesn’t mention that between every other step there is
- pour a dram
I thought that was a given with me…
