Cutting fluid recommendations
anyone have a recommendation on cutting fluid thats on the less smokey side? if thats possible to get away from
Water works well.
it is not as much as the fluid causing smoke…it is the burning/melting of metal…
all the water and fluid additive does is help prevent warping provide heat distribution…as well as cutting down on the sparks.
good ventilation…air filtration…and if you can a “Smoke Eater”…is an option
