Hello. I’m new to this kind of equipment. I was wondering, what fluid do I put in the table? Thank you.
Welcome to the Forum Lee !
I use Sterling Blue in my table SterlingCool-PlasmaCut (Premium Plasma Water Table Fluid) - 5 Gallon P – Cutting Fluids Direct
Others use Plasma Green. Amazon.com
If you shop around you can find at least Plasma Green in one gallon containers.
Some of us still just use water…been fine for years. Did a deep clean last weekend and, other than ready to change slats, the table cleaned up like new.
Welcome to The forum @LeesRailings
If you don’t mind me asking for what reason did you buy your XR?
When you get up and cutting make sure you come back and post some projects.
here is your affordable option. Amazon.com: Plasma Table Green Cutting Fluid Powder & Radiator Repair Test Tank Cleaner - 3 Bag, 12 Oz - Green Fluorescent Dye for Leak Detection - Made in USA : Tools & Home Improvement
I have seen the plasma green on amazon. What’s the difference between the 9010 and the 1050?
I started a metal fabrication company. I’m specializing in railings, but I am wanting/hoping to do other projects as well. I worked for another company for the last 10+ years doing this. That company had a plasma table. I knew just enough to use it but not enough to know g-code, when tips were going bad, cutting fluid, etc. So this is a good learning experience!
I tried that stuff and it seemed real caustic and left white build up all over the table.
