Has anyone tried cutting brass or aluminum? I’m using an XR and the Razorweld 45. Would love to hear what speed, voltage, and torch heights to use. Thanks!
@hagan279245 Welcome to the Forum .
I have cut quite a bit of 1/4 aluminum but no brass on the XR.
Cutting simple shapes works very well , Art pieces on thicker material with a lot of pierces can but finicky. Just be on the look out for flakes of aluminum sticking to the nozzle after a pierce it can redirect the plasma stream and obround the nozzle very quick , almost instantly in some cases.
I use a Hypertherm but I have had success with the factory cut charts
Some aluminum 1/8", 3/16" you are not going to cut brass or copper over 1/16" at max amp and it would be slow.
