Hey Guys,
What is the best way to cut aluminum on the cross fire. Been cutting a lot of steel and got it tuned in great. But aluminum is another story the edge always comes out bad. I am running a EVERLAST Plasma cutter. Aluminum is 0.1450" Thick. Feed Rate 50IPM Power 28AMPS Air Pressure around 66psi (On Dry Compressed Air). Also Tip is new in torch. Should I be using different gas??
