Cuts the holes fine, starts the profile and torch stops firing, air flows, XY movement continues. Trigger won’t fire manually. I’ve tried lower air pressure, slower speed, ground on material directly, two shots of tequila…
May have it fixed. Switched to whiskey and then found corrosion on the ground clamp. Cleaned it and scuffed the material and clamped directly onto material. Completed the profile cut!
Agree. I’d be using the .8mm tip, 30A and 80ipm. Actually, with the RW45, I’d probably be going 45A and 100ipm to start. No need for lower amps unless using the .6mm tip for fine cuts. Higher amps with the right tip means faster cuts.
You need to use the right consumables as the torch you have is not a S45. 0.8mm is the 30 amp tips. If you plan on using the S45 consumables you need to get the right swirl ring ebay number 173702219697
These are the consumables you need to be using ebay number 183831579043 along with this swirl ring ebay number 183740136337
Yes. Although if I used the 45A settings I’d step up to the 1mm tip.
As a rule of thumb I use the .6mm up to 25A, .8mm for up to 30A and the 1mm for up to 45A.
You can use a higher capacity tip for lower power but overpowering a smaller tip will burn them out faster. So you can use a 1mm tip on any setting but the .6mm needs to be 25A & below. The disadvantage of using a larger tip than its rated power is a larger kerf. For a lot of cuts that’s not an issue but for fine details in art projects it might be.
