Any ideas why my plasma cutter seems to ignore some M3 and/or M5 codes. it will literally cut one hole then move to the second hole but never turn off the cutter, even tho there is a M5 command. doesnt do it all the time. i notice it will also stay on when finished. gets to the end and doesnt turn off cutter. thanks, Dave.
Is your plasma cutter set to 2T?
looks like its in 4T mode. i’ll change it and report back. thanks for the quick reply.
That baby needs to be set to T2, ask me how I know!
Works much better! on the Razor 45A the switch with the arrows pointing in diff directions is 2T, the arrows both pointing down is 4T. now if i can just figure out how to make holes that are actually circles. thanks for the help.
